Portable Round Top Storage Sheds
205
Chicago, Illinois
Does anyone store their duece in one of those portable (round top) storage sheds? If you do, what size do you have (w/ or w/o winch)? I am possibly looking to get one to store the duece in the winter but would rather not get one too huge. What's the minimum size anyone hase used for their duece? Are you able to drive it in/out as well?
1,331
decatur alabama
id get one thats atleast 10' tall clearance... 9' minimum. and atleast 25' long if you have a winch truck. but it remeber it needs to be 9' tall at 7' wide if your trying to make it tight so the cab can clear.. taller if you have a cargo cover on it
or if you have no cargo cover, willing to take the top off, drop the window and take the muffler top off you can put it into a cars garage with a 7' door ;)
sprucemt
14
Warrensburg NY
I use a two large fabric tension buildings. My most recent is a ClearSpan purchased thru Tek Supply. The Solarguard that I have is 26wx12hx36l. Round style frame with Forest Green 12.5 oz, 24 mil premium, 15 year warranty material, with a skylight. Depending on snowload, you may have to order more rafters to compensate. I am very pleased with this unit.
I have another unit that is 26wx10hx42l that is a "StrorageMaster style" (pitched roof). This style is a nightmare if you are in snow country.
The round top is far superior in snow country. You can check these out online at www.teksupply.com
Irv
Noxon, MT
I have used the (used to be) cheap Costco tents that are 10 wide, 20 long, and too short. I raised each leg a couple of feet with PVC tubing, which was just the right size (2"). The sides don't come all the way to the ground and it looks like a pair of high water pants, but works fine. Drilled a hole in the side of the PVC and inserted a long nail into it to keep the steel tent frame from falling down through it. Stored a 9 foot tall M75 APC in there just fine. To keep it from flying away, I used a rope at each end of the ridge pole to come down and tie off on the vehicle.
BobM
Fillmore, Indiana
nopics
