Positive Camber
McSpeed
293
Palmer, AK
Do all four bolts come out of each upper control arm mount or just loosen the bottom and remove the upper bolts to slide the shim out???
infidel got me
32
Newberry, Florida
Most of the snowflake alignment shops nowadays wont fool with anything that is not just toe n go.. sad days boys... ended up doing my own alignment at home. My buddy had a set of camber/caster magnetic bases and turn plates from his race car days. Total time was 5 hours, but shes straight, no tire wear, cost me a case of beer (I helped drink) and when you let off the throttle it actually will coast now..
FKAM
64
Duchesne, Utah
Just did my rears and if your lucky like I was and they are the slotted ones and not the plates you just can just loosen the bolts and slide them out. I just had one per bucket.
AOR
37
Burtonsville, MD.
I have had my M998 for over a year now I have been bolting on heavy parts and plan to have someone align it for me soon. As I recall hen I looked at where the shims go it looks like there are currently no shims in there and I have positive camber.
How can camber be adjusted to remove positive camber if there are no shims to remove?
