BigMontana
- 50
- 18
- Polson, MT
There's a plate on the trans side of the engine trans connection, maybe this is supposed to be missing so you can adjust something, or maybe it's a shim bolt...the one on the other side has like 4 washers on it, so that makes me wonder if there's a set depth or adjustment needed instead of just cranking a bolt that fits into the hole.
The yellower bit is the bottom of the oil pan at the aft/back of the engine.
