- 7,418
- 2,521
- 113
- Interlachen Fl.
Good find on the fork lift and motor. Does look like you had a good azz down load.Picked up the forklift the other day.
Right now at Peack Tire Service getting a new trailer Tire and four truck tires.
Yes. They do well at 30 to 35 on smooth roads with a heavy truck like a 5ton. At about 40 they will drag my 5 ton around though if they sway. The towing manual says 35 is max.Even longer at 10-15. Could one of these be pulled at 30-35?
Nice FT Phil! I've wanted and needed one of those fork-trucks for a long time. I'm entirely in sand so anything less sinks. I have 2 trailers of machinery that need unloaded, sinking into the ground.
It looks really nice condition...and now your tires do too!
I had the forklift sitting back over the trailer axles when I started. Had to make a sharp U-turn in a small parking lot. That is were I think I may of damage the sidewall of the rear tire.Good find on the fork lift and motor. Does look like you had a good azz down load.
Thanks,Even longer at 10-15. Could one of these be pulled at 30-35?
I may know where a few of them are. I will make a phone calls.Thanks,
Truck is happy now with the new tires on the back. Going to have to replace the front also.
Forklift tires are like new. Only main problem with the forklift is the forward and reverse cable is almost broke into. The city in TN said Case doesn't carry that item anymore and is the main reason they sold it.
That would great. I would take two if you find any. I think the Forward / Reverse and the Trans shift(1,2,3) cable are the same.I may know where a few of them are. I will make a phone calls.
Sent from my SM-G935P using Tapatalk
Let me know if you find some. I would like two of them. Part Number: L102565I may know where a few of them are. I will make a phone calls.
Feel free to regularly check out the stock of Chariots GCS. I saw they have these in stock sometimes.I need to find me one of these little M4KN's. They look real handy!
