post a picture of the brake lines between the carrier
mendo
10
Meadow Vista, CA
Will someone post a picture of the flexible brake lines between the carrier and the truck from underneath?
I have attached a pic of mine, well, what is left of mine, the parts between are missing. I want to replace them.
Thanks!!
Gamagoat1
36
Kiowa, Colorado
If you have three, one is the fuel line to the trailer heater. Ambulance had em. It should be short and go to a fuel pump on the bulkhead next to the right (passenger) wheel in the engine compartment.
The third one in my pic is the vent line for the rear diff. It goes up into the void in the front of the trailer.
mendo
10
Meadow Vista, CA
Must be the vent then, there are only 2 flexible lines. or what used to be them. I gotta replace the flexible lines between the tractor and the carrier, someone cut them. and they cut the hardline, not the rubber! just to make it harder on me I believe!!
Thanks again!
