Post search battery questions
iacucv
Spencer, IA
Ok, so my rear battery died on me but luckily the front had enough in her to get the truck (m1008) started not once but twice. I'm pretty sure these are civy batteries but there is little to no marking on them. There's a few stickers, batt that ate it was manufacturd in July 07 and the front one which is only putting out 400 cranking amps and close to the grave is February 09.
So, after searching the battery threads etc I saw conflicting posts on the need to put matching manufacturer and manufacture date batteries in the cucv. I assume its a non issue since mine has worked fine but who knows if that's what cooked the rear. I find no marking of ca and cca, so will it make a difference if a buy a battery with a different ca/cca rating than the front? I'm a little strapped right now so I am hoping to put the front battery off for a week or two but definitely get it done before winter.
What help can you guys offer me? Thanks!
Skinny
495
Portsmouth, NH
You really should have matching batteries for your 24v parts to be happy.
I am very happy with my Exide group 31 batts from Tractor Supply. $200 and I was out the door.
Warthog
241
OKC, OK
You should have an Interstate Battery on town. They should have group 31 refurbished batteries for under $50.
In the Cucv, which has separate alternators, matching batteries are not as important as they are in a single alternator system like a Deuce. Matching batteries will perform better.
