Reviving because I've added one of these as a new toy to my line-up.
Mine is the older variant with the threaded connections. The surplus store had sold out of all the QD type, but still had the hose assembly lingering around, so he threw it in for free for me since I had some interest in it. In looking up the part catalogs from numbers stamped on the fittings, all the QD fittings are just standard brass industrial air hose couplings with Nitrile gaskets, so I'll grab the appropriate connectors to fit the actual metering valve (and replace the line going from the burner assembly to the metering valve). Should be nice just having the new-style push-to-fit connection rather than threading them.
For anyone with these, any idea how hot they're supposed to run? I check with an IR thermometer and on my lowest possible setting in the diesel range, the top of my space heater was at 900F, which has it faintly glowing in the dark. As well, if I completely close the top lid, it seems that it like to not burn correctly, leading some vapor to be burning in the stack instead of in the firebox with a bit of a surging/chugging effect. It seems like this is the fuel rate being too high, despite the settings limiting this?
