Post your H45 heater setups
Wire Fox
161
Indianapolis, Indiana
Mine are all still in the shipping boxes that they were put in when they were manufactured. Seems nobody wants these things anymore.
Sad! But they're large and awkward for use in anything but a field tent. And even then, most people want a wood-fired stove in order to just use locally-sourced fuel instead of buying liquid fuel from not much farther away... I'm intending to build a semi-permanent stack assembly for use during the cooler months on my covered back porch. Basically will be an appropriately-rated wall panel and thimble pass-through, and an angled chimney pipe to pass through. Should make a ton of heat so that I can enjoy my porch all year!
I'm also working on making a liquid heat exchange system to safely use the stack heat to heat "anything else" without worrying about a special chimney stack, stove jack, or anything of that nature...just setup the heater outside, place the heater core inside the vehicle, tent, or small structure, and hook up the pumps/fans to a 12V power source and you're then good to go with a much lower safety risk. Half the parts should be sitting on my front porch now, and the rest are all to be locally sourced from Napa and Lowes... I will definitely share some pictures if it ends up working well!
gimpyrobb
dumpsterlandingfromorbit!
27,786
759
Cincy Ohio
If you plan on ever camping, look into a zodi shower system. It uses a nice battery powered sump pump that would work for a heat exchanger pump.
