Power Bleeder pt2
1,814
Well, since I've been playing with the Hotel Delta (Home Depot) power bleeder lately, I've added another attachment. My semi trailer uses the same exact master cylinder as the M105 (and just about any 1 1/2 ton trailer.) Since I've had the semi there has always been one axle without brakes so I decided to adapt the power bleeder to the trailer. It has 2 air chambers, 2 master cylinders, 2 wheel cylinders per wheel and one relay valve. Since I have the M015s in the yard I made this up to fit them too since they share the same cap. The M/C cap has a vent provision via 3/8" inverted flare steel line so I bought an 8" piece of steel line, added a little bend and a brass adapter taking it from 3/8 inverted flare to 1/4 NPT then added the quick coupler. Filled and bled everything on the semi trailer and now it has brakes on all wheels, and good brakes too! Attached is a pic (poor one) of the piece attached to an extra M/C cap.
M543A2
10
Warsaw, Indiana
Kenneth:
Yes, this works great. We did it some years ago when my son got an M139. To try the pump the pedal, hold,
bleed, etc. maual method just will not work on these vehicles. The power bleeder allows you to flush the system as well.
