Power inverter system, dc to ac,
NEIOWA
128
NE IOWA
Anyone have experience with this unit of similar can report on?
6130-01-552-6350
The Quiet Power DC to AC Inverter System (QP-1800) is comprised of one QP-1800 Inverter, one
NATO Slave Input Cable, and one Transport Case. This semi-ruggedized system converts 24VDC to
115VAC (pure sine wave) enabling operation of 115VAC powered devices from vehicle 24VDC power.
http://www.marcorsyscom.marines.mil/Portals/105/pdmeps/docs/APS/H0004.pdf
gimpyrobb
dumpsterlandingfromorbit!
27,791
787
Cincy Ohio
I have not used THAT one, but have used a couple other 24v inverters. 1800watts isnt that great for the prices I've seen them(that model you linked to) sell for. I picked up a 1500w unit for 100.00 and love it.
1,193
Yes, I had one.
Unless you need perfectly clean power for some sensitive electronics, it is overkill.
NEIOWA
128
NE IOWA
Uncle pays $4,671.85 for these in a nifty Pelican case with slave receptical cable. Must be an extra super-duper special case but I'm thinking the inverter likely is a bit higher quality than a Harbor Frt item. I have had a cheapie 12v Inverter that wasn't worth hauling home.
gimpyrobb
27,791
787
Cincy Ohio
I understand what your saying. Mine wasn't a horrible freight version, it was mil-spec. If your happy with the specs and price, pull the trigger. I just think its too much for what you get, thats all.
NEIOWA
128
NE IOWA
Mil surplus is available from DLA to Fire Dept for the cost of the freight. From some categories, from some depots, they will even ship it.
Jericho
72
Landaff NH
unless your adamant that it has to be Uncle stuff , I have been running twin DR 3624. 3600 watt, 24 volt dc to 110 /220 inverters for 23 years 24/7 365. I run TRACE inverters which was bought by Zantrex, which was just bought again, Trace made the best in the world for years . With inverters, you get what you pay for I paid $2200.00 each in 1996. They are actually MUCH CHEAPER now
Jericho
72
Landaff NH
Match the FSN to the assigned part number, AF used a lot of Trace inverters , then run a search on the items for use available for the MUNICIPAl draw. don't forget the Guard and reserve, Guard historicly does its own surplus disposal
Swamp Donkey
The Engineer
126
Gray, GA
The case is a Pelican 1560.
I love my inverter. Been running a Dewalt chopsaw with it to make fence posts out of old water pipe. The first inverter I got was a Ebay 2000w/4000w peak. It got hot and failed after 2 cuts. This one doesn't even flinch and has made about 175~ cuts so far. It can also be used to run the TV, router and Playstation during power outages to keep the kids entertained, since it makes clean power. My Pelican case will be here Tuesday.
