Power steering bleeding help needed
Milcommoguy
2,422
Rosamond, CA
Guessing not allowed, but your on the right path. Every action... opposite reaction thing. A dap of grease and no vice action. Bending or warping up a stamped pulley is bad news. Maybe cast?? Shouldn't be that big a deal. Get some extra hands on the pulley. If it has a hole off to the the side, lock it up with something. The proper tool does all the work. Leave the hammer in the tool box. You can do it.
Grease, not the country, CAMO
juanprado
3,204
Metairie/La (N'awlins)
There is a tool to remove the pulley as well as a separate tool to install. Any parts store will have them in their loaner tools like autozone, O'reilly, advance, and better Napa's. Does not cost anything to use these tools just a deposit till return.
Pulley typically installed flush with the top of the pump stem and will also usually bottom out on saginaw gm style pumps.
Lazboytt
Michigan
Sounds good. I don’t plan on using a hammer as the last person killed the other pulley. Thank you for all your guys help.
NormB
119
Hampshire, TN
An ebay deal from about ten years back. Think it was about $220 delivered.
I disassembed it, sand blasted and parkerized it, then gave it a coating of I don't recall which rattle can paint.
Came with the lead jaw pads - and I bought a couple sets of other ones in rubber, aluminum and plastic.
One of the best tools in my shop. Planning on a place of honor for it in my new shop in TN. Soon.
I used an old leather belt on the pulley though.
