Power Steering Leaks
Sarge29
Saluda, SC
I just went through the power steering on my 998 and found a couple leaks. One leak was the seal on the input shaft on the steering gearbox and the other was the pump. I pulled the gearbox off and cleaned it before tear down. I pulled the top lock nut off and removed the packing gland. Then I went to the local NAPA store and picked up a replacement seal and a power steering kit NAPA number 7-262. I pulled out my O ring kit and found the correct right size O rings. I put everything in and reassembled the gearbox. After putting the gearbox back in I pulled the power steering pump. Again cleaned everything, installed the seal kit and put the pump back on. This process took a little over 1/2 day. Now the moment of truth. I followed the TM on bleeding the system. After running the truck for a few minutes I shut it down to look for leaks. No leaks. The next step was a test drive. After a 10 mile run everything was good. Parked it in the shop for the night to see if any leaks show up on the concrete. The next morning, still no leaksfat lady sings. Now I have all of the mechanical and electrical issues resolved I plan on stripping it down to prep it for paint. Still need a few parts but I think I will find them before I get the painting done.
nf6x
Feral Engineer
1,630
50
Riverside, CA, USA
I remember when I had leaky power steering. For a brief while before I worked out the kinks, I got pretty good at pulling over n the side of the road, fixing another leak that showed up, rebleeding the system, then continuing on my way. :beer:
