Noticed my power steering pump vibrating badly. Found only one loose bolt holding it to it's bracket. The second bolt was sheared off and there was no bolt in the third hole. Bottom bracket was also very loose. Yikes!... All the bolts that hold the pump in and it's bracket to the engine are metric. What size is the bolt that is used to pull the pulley on the shaft? An M10-1.25 or 1.5 won't go in. An M8 is too small. I tried a 3/8 course and it threads all the way in with very little wiggle once you get it in 4 threads or so. Any help appreciated before I screw up my new-reman pump.
