Power Steering Pump Pulley Removal
AnEyeL8
Red Lion, PA
I did a search and couldn't find anything in the forums, or the rest of the interwebs...so here it goes. I never post in forums and usually only use them for research, but I'm hoping someone has a trick up their sleeve that will help me out. The following is in reference to an M1097A2 (6.5L NA).
Today I started what I thought was going to be a very simple power steering pump swap. I followed the TM to the "T" and I couldn't get the pump out from behind the mounting bracket. I'm assuming that the TM is wrong and I should have removed the pulley first, which I actually tried and failed at doing. So here I am, frustrated, with a power steering pump loose in my engine bay, stuck. The pulley seems to be seized on the shaft and I don't have room to do much with it. I have a pulley removal tool (I actually have three different types) and none of them are compatible with this type of pulley.
So here I am, looking for suggestions. How do I get this dag-gone thing out?
Mogman
8,573
Papalote, TX
Welcome to the SS forums!!
I always remove the complete ass so I can fight it on the bench.
AnEyeL8
Red Lion, PA
Thanks for the warm welcome!
Unfortunately, that's exactly what I was trying to do, and no matter which way I turn/tilt/rotate/curse, it refuses to come out. If I can get the pulley off, then I think I'll be smooth sailing...if I can find a removal tool that's compatible.
tgejesse
285
Maryland
I just dealt with this on my 1165.
I first removed the belt, then took the bolt off the front of the pulley. Then the fun…. HAMMER turn, HAMMER turn, until she comes loose one millimeter at a time. I beat the crap out of my pully and when it finally came lose I washed it down, used a dremmel to clean up where it was seized up… went back on my new pump like new. Hard to hurt that OEM pully. Good luck.
Retiredwarhorses
3,936
Brentwood, Calif
there are two different serp setups for A2 trucks, and that means you have one two different PS pumps…a pic of you serp setup will
determine what method you use to R&R the pump.
AnEyeL8
Red Lion, PA
This sounds like so much fun! lol I guess I'll be trying that tomorrow.
I also found this guy, which looks like it would work great.
I'm just not sure I wanna drop $100 on a tool that I'll need for less than 10 min.
AnEyeL8
Red Lion, PA
It's the "SERIAL NUMBER 196900 AND BELOW" setup. I don't have a pic on hand at the moment. It's the one with the reservoir attached to the back of the pump.
tgejesse
285
Maryland
My dad had a puller but we didn’t have the clearance to use it. This looks more low profile. Might work. Hammers work for sure! Ha
Retiredwarhorses
3,936
Brentwood, Calif
so you have an early serp, pump is an RCSK18330, you need to remove the upper radiator hose and take the pump out the top With the pulley still attached, removal and installation are done on a bench.
AnEyeL8
Red Lion, PA
I'm not sure what the hang-up is under my hood. I removed the upper radiator hose, which gave me more room to reach in with my hands, but I still couldn't get the PS pump out.
AnEyeL8
Red Lion, PA
Final follow-up in case somebody needs or wants to hear it in the future. I removed the thermostat housing, which gave me enough clearance to easily remove the power steering pump and reservoir with the pulley still attached. So, I'll have to order and replace the thermostat gasket, but it was a very simple step that made things easy.
On a side note, the pulley was a PITA to get off, even with a bench vice to hold it while I used a puller. Either way, I'm one step closer to getting this all back together.
