Power steering pump
gimpyrobb
dumpsterlandingfromorbit!
27,786
763
Cincy Ohio
I've had some guys ask about the 5 ton pump that can bolt on the multifuel. Here are some pics so you can see what it looks like. I was asked about the mounting "cup" and the gear to turn the pump. All I could say was I don't know. If someone bought a pump and it didn't come with the gear and adapter, is there a part#? Where can you get them? Also, there is numbers and letters on the bottom that are stamped to indicate pressure and flow rates. I could not get the pics to turn out. Hope this is helpfull.
gimpyrobb
27,786
763
Cincy Ohio
The one that looks used(taken apart) is the busted one from my multi in the wrecker. The rusty one came from Hammond's place. I am going to rebuild both and use them on my other trucks. The pumps are not hard to find but the 5 bolt adapter and the gear that goes in the motor are scarce. That is why I was asking about sources.
