Hf-54
Hi
The HF54 with casting hf54053, you may have a problem to mont, I have get good info from gringeltaube, and done some on my one.
At the moment I working with my project and using the HF54, casting hf542998, and what I find is that the power steering HF54 with casting xxxx96 and xxxx98 is easy to use.
Gringeltaube say some about the pitman arm's length, I have found out with some help that a long arm gets a fast steering, shorter slower steering.
But the angel have to be 90 deg. may some adjust to, camber, caster.
And the HF 54 is exact good to use if you calculate the power you need to steer the truck, out from the data on the front axle and weight on the truck.
I also do some other things on connecting the box with the steering colum.
a bit easy
( have not mail Gringeltaube on this yet
![Rolling Eyes :roll: :roll:](https://www.steelsoldiers.com/images/smilies/icon_rolleyes.gif)
The pump is still in use, the problem is the adapter so adapt the pump to the engine.
So all 5 tonner multifuel pumps take care of them. ore only the adapter.
I get my HF from Doug Jones Metro airport truck (dougjones@matruck.com)
he is most helpful
But my problem is to find me some pitman arm's
So any so now give me a hint.
Come back with more later, when I get done more...
Odd
There is other ways to do this, using other PS... also
