power surge??
tigertank
angleton texas
every once inawhile ill get a surge the alt gauge goes from green all way to red at highest point, and if the fan is on its will blow harder. then it will just quit and go back to normal. is this a voltage issue??
donquijote
36
Louisiana
Your alternator is bad probably. Just had the exact issue and fried everything in my truck by continuing to drive it. Lights, alternator, starting box... all toast. I would check that and not drive it so you don't end up with a more expensive fix than just a alternator
Sent from my SM-G935P using Tapatalk
DatGuyC
22
Essex, Maryland
Same thing was happening to mine. I have the 60 amp alternator and just replaced the voltage regulator board in the back of the alternator and it fixed the problem.
infidel got me
32
Newberry, Florida
I installed a 21si single wire 24v. I ordered it online/with a 2 groove 7/8 bore pulley. You will have to do a little fab work ,but nothing hard. It wont overvolt and fry your electronics. 74m35a2 sells them also-- he's a member.
