- 7,744
- 155
- 63
- Columbus Georgia
Well - while you knuckleheads PO your better halves (and ya outta know better by now NOT to do that) I was trying to get some work done while your thinking about food.
ALL 4 tires mounted - the 5th is getting (you folks with kids will love this - is on TIME OUT) as soon as I get a few minutes I will teach it Zout spanking.
First pic of the wipers I put them on up-side-down - so that's cured now - put new vacuum hoses on them as well.
Got the holding tank out of the 109 and the only thing that's left to get off is the Onan generator up in the overhead above the cab on the exterior - I will not tell ya what I did - but I did call it a day for now and just got up to
the house finally - I need a more level drive or a garage next to the house is all I can tell ya.
OH yeah PB - I filled the trans first thing (pics are the grease I use and trans lube) and the shifter shaft on the PTO output started pissing lube - I will get a new seal.
I sure hope I put them NDT tires on the right direction on the rims
