Preping your deuce for paint
zout
155
Columbus Georgia
Some day I am going to learn how to do body work but one of the biggest things when you go to Prime and Paint - pay attention to the temperatures and humidity outdoors unless you have a sealed down draft paint booth system to spray in.
There are many array's of paints and chemicals that do not match each other as well.
From my statements I approached this that most are spraying outdoors in a slightly sealed off area - or in just a really big garage.
From the automotive end there are endless threads of how to from start to finish and it relates totally to MV's as well.
As far as safety - get the best da* respirator money can buy - if you can get an air suit - go for it. Its only your lungs. If you ever saw the chit you spray dried up in a bottom of a bucket you will get the idea. Spraying outside - pay attention to where that overspray and fumes are headed.
swbradley1
Modertator
1,899
Dayton, OH
I do it the same way another member showed me and his trucks looked pretty good. Simple and easy and still looks better than a motor pool job.
Pressure wash anything loose and clean the entire truck.
Mask what you want.
Prime it with Rustoleum.
Rattle can it with Rapco. (Single color takes 20 cans per truck)
Done
gungearz
northwestern indiana
Make sure when your using sanding disks, that you work fast on a big area. To much heat from working on one area will warp a panel... Then it would take the fire and ice method to reshape it back.
gungearz
Yep, very true! I've learned that one the hard way! Sandblasting can seriously warp panels too.
Yea... I found out the hard way with sandblasting also. Until I found out that thin metal shouldn't be sandblasted but mediablasted instead. The best universal media I came accross is dry ice blasting.... Unbelievable results with very minimal mess.
tco3129
Flat Top W.V.
I thought OD green was OVER DIRT green. I took a putty knife and popped off loose chips and took to carwash. Was dry by the time I got home so I fired up the paintgun and WALLAH?, I had a green truck. DONE!
Kloakndagr
On The Road/California
Here's a question for you guys....anyone think bout painting their duece using a truck bed liner, you know the entire truck. Would kinda intimidating and be pretty durable. Just a thought.
welldigger
Benton LA
Pretty much exactly what I am going to do. So far I have decided to use durabak. At least until someone points me to a better product I don't have to tint myself. They offer od green with UV inhibitors as an off the shelf color.
