Presure switch issues
TURKEY131
Barnegat, NJ
While driving my M931 yesterday I noticed a drop in air pressure and could hear air leaking. I located the culprit (MFR-61782 19207-12375453). It looks like it blew apart. Would does this switch for? Any ideas on where to get a replacement?
TURKEY131
Barnegat, NJ
Warthog, I tried I googled the part number, I was doing searches and did not come up with anything. Thanks for the response. Suprman I PM you, Thanks.
Warthog
241
OKC, OK
I googled 12375453 as that is the part number. The rest isn't needed.
juanprado
3,143
Metairie/La (N'awlins)
There is also a check valve at the end of each tank. Make sure it is not frozen up. Some have reported issues with water in the system due to the tanks not being drained regularly and the the check valves rusting/crudding up especially since you are in the land of cold and freezing temps.
The check valve is a midland kn23000 available at NAPA or your favorite hd:
http://epi.hbsna.com/Products/Produ...49F69A7D45FF6CD5637A&pf_id=KN23000&dept_id=58
Suprman
705
Stratford/Connecticut
This is the new style switch. You can disconnect the switch and use a piece of wire to short across the connectors on the truck that go to the switch or you can meter the switch with 85 or so psi in the tank and see if its closed to test it.
