Pretty sure my air packs shot.......
sgms18
85
North Augusta SC
Well, I found one that is supposed be NEW & not NOS. Guy said they bought it from the manufacturer less than a year ago
Floridianson
2,514
Interlachen Fl.
Just make sure you use some air tool oil on the incomming air line and the square canister plug before you use it. Can be done on the work bench. I might stand the air pack up when you do the square plug and twist the whole air pack around to get the oil all over the walls of the cylinder and to get the seal well coated.
Floridianson
2,514
Interlachen Fl.
I would just use regular air tool. As for the square plug in the canister I might go with a couple of ounce's and rotate it around up and down round and round then drain out when ever comes out. Then just service it on a regular bases using the amount the TM calls for. I have found two different amounts in two different books.
Floridianson
2,514
Interlachen Fl.
Ok. It will be next week before i have a chance to work on the truck. I'll let yall know how it turns out.
My military International Harvester book says to fill it till it runs out after install. That seems like a lot but it does say after install. I can't remember what our TM's say but it was not like that. Also says every six months but I bet that is when heavy use. Guess we could discuss the different amounts or at least post up the two differences are. Think the big problem is no air dryer on the Deuce.
Floridianson
2,514
Interlachen Fl.
Rustystud started to get a nice TM together on the air pack but I don't think it ever got updated with the rest of the pages. Maybe he could finish it off because it looked like a good one. Or maybe he could look and see what his book says for the lubercation if nothing else.
sgms18
85
North Augusta SC
Never hear of vacuum cylinder oil. Is that the same as vacuum pump oil? Most of what I've read says use air tool oil. Admittedly i haven't read the TMs yet.
rustystud
3,258
Woodinville, Washington
The military used a special oil that costs about $50.00 quart. The only way to buy it is in 55 gallon drums. It costs a lot of money ! I once tried to get a group of Steel Soldiers to buy a drum but no one wanted in. Every now and then I check on the price. It still is obscene !
Using a good air tool oil should be fine. After all most have not been lubed since leaving military service, and their still working.
When rebuilding mine I use "Silicone Grease" to lube the piston and bore. It lasts a long time.
Floridianson mentioned installing an "Air-Dryer" in the air system. That is an excellent idea. It keeps crap from interfering with the operation of the "Air-Pacs" air valve. I installed one a few years ago now and my whole air system operates in a most "excellent" fashion !
I know, strange choice of words. My blood pressure medicine is off and the doctor is experimenting with new ones. I'm feeling pretty weird right now.
sgms18
85
North Augusta SC
Man I hope the Doc gets your meds straightened out.
Is there a write-up on here anywhere on your air dryer install? I would love to read more about that. Sounds like a "most excellent" idea! Really seems like something that should have been on the truck from the factory.
