I had an "install" post somewhere.Man I hope the Doc gets your meds straightened out.
Is there a write-up on here anywhere on your air dryer install? I would love to read more about that. Sounds like a "most excellent" idea! Really seems like something that should have been on the truck from the factory.
I'll try and find the manual. The house is still in disrepair due to the kitchen/front room remodel. Boxes everywhere. I cannot remember where I put it at this time. I know the general area though.Maybe when Rusty gets feeling better he can look at his repair manual. Then we can see the amount of oil his wants put in the piston chamber for servicing.
The military used a special oil that costs about $50.00 quart. The only way to buy it is in 55 gallon drums. It costs a lot of money ! I once tried to get a group of Steel Soldiers to buy a drum but no one wanted in. Every now and then I check on the price. It still is obscene !
Using a good air tool oil should be fine. After all most have not been lubed since leaving military service, and their still working.
When rebuilding mine I use "Silicone Grease" to lube the piston and bore. It lasts a long time.
Floridianson mentioned installing an "Air-Dryer" in the air system. That is an excellent idea. It keeps crap from interfering with the operation of the "Air-Pacs" air valve. I installed one a few years ago now and my whole air system operates in a most "excellent" fashion !
I know, strange choice of words. My blood pressure medicine is off and the doctor is experimenting with new ones. I'm feeling pretty weird right now.
Well I figured I'd update yall. I got the new air pack on & bled & I got brakes. The pedal is kinda soft but it doesn't go to the floor, its consistent AND it stops the truck so I'm happy. Im on the road for the 1st time since i got the truck!Im sure the pedal will get better once i get the wheels off & go through everything. New brake hoses & wheel cylinders are in order & prob shoes too. Im guna start at the front axel & work my way back & service everything brakes, seals, bearings, new gear dope, both of my front knuckle boots are busted & the list goes on. Been a long time since I had a project truck & it feels good.
