primary filter help needed.
1,165
Thanks Ace
So on the threaded shaft, is there something like a pin going through it to keep item #10 from sitting on the bottom of the canister?
Becuase in mine, I think the spring is sitting on the bottom of the canister...and the drawing shows it suspended above.....
cranetruck
94
Meadows of Dan, Virginia
clinto said:
Thanks Ace
There is a "shelf" on the threaded shaft and the spring sits on a washer (may be missing on yours).
1,827
I've encountered more than one where the primary filter was hanging out in the bottom of the can doing nothing.
jasonjc
289
Gravette Ar.
I replaced all mine a few weeks ago. And there is some thing on the shaft to hold the spring up, pin or a grove or some thing can't remember what. But your is missing some thing. And as for the end gasket being glued off center, I just got some millitary supuls ones and 1 of those is the same way. Off center.
