Primary fuel filter different ?
rrrr
Missouri
The primary fuel filter I took out fit the center rod nicely. The replacement is much larger with cork on both ends ?
The filter flops around inside the retainer because the opening is soo much bigger. Its a wix 33511. Is this correct ? Do I flip the brass support on the bottom of the filter upsidown to help center the filter in the assembly ?
thanks
jatonka
87
Ephratah, New York
Yes, turn the cup over, it will help. The correct filter is NSN2910-00-790-2300. Hard to find.
You could get my primary spin-on adaptor and end the problem. see the website below. JT out
dabtl
Denton, Texas
Everyone needs to put the primary filter can into the trash. I have not seen one that is not rusted and nasty. JT makes the easiest of the adapters to install, in my opinion. Very quick to install and works like a charm.
If you do not use JT's adapter get another from OD Iron or someone else. You will not regret it.
dabtl
Denton, Texas
No matter whose product you choose, and there are several, you will be doing your MV a big favor by switching to a complete spin on filter setup.
