Prime oil pump on Multifuel?
Stretch44875
Super Jr. Moderator
33
Tiro, Ohio
Is there a way to prime the oil pump on a Multi-fuel that has been sitting?
Thanks,
Dennis
Stretch44875
Super Jr. Moderator
33
Tiro, Ohio
Lets see, either nobody knows, or you all don't like me! I'm going to go drive the deuce till I feel better.
Dennis
alphadeltaromeo
Alto, GA
Why not just get some spin-ons and solve the issue without having to do plumbing, etc. Mine builds pressure very quickly with spin-ons...2-3 seconds normally and 4-5 if it's been sitting for a LONG time.
JasonS
202
Eastern SD
There are a couple of ways that you can do this. You'll need an external pressurized source of oil. Here is what I did to prelube my Reo gas engine. I took a 302 gmc oil pump which can be spun with it's mating distributor, built a bracket to hold it in a pan of oil, used hose to route it through an external spin-on oil filter, and then finally into the engine. I rotated the engine while prelubing. The pan was located under the engines open drain hole so that the oil could be recycled around. Another method is to use a pressurized tank of oil.
cranetruck
94
Meadows of Dan, Virginia
Re: RE: Prime oil pump on Multifuel?
That (anti drainback filters) works if you don't need to preheat the oil in the pan..
Stretch44875
Super Jr. Moderator
33
Tiro, Ohio
Guess I need to be more clear. Not interested in a pre-lube system. I'm talking about if the engine is been in storage, or freshly rebuilt, and need to pre-lube the engine for the first start.
I do have some ideas for a pre-lube system, and have read the threads on here, but that's down the road some.
JasonS seems to be on the right track. Had to laugh at your pan, I have cooking pans for oil catching also...
I have a 12v oil pump, I'll just pump a 5 gallon bucket of oil in the pre filter port of the oil filters, and give it a couple of spins.
Thanks!
Dennis
