Primer on modern tire upgrades for the deuce?
kochevnik
Colville WA
Well, I would really like to stick with singles in front and duals in back.
Michelin XZL's seem to look really nice. Also suit my purpose (highway and off-road) And I like the specs shown for the 11R20s on that military tire comparison chart another poster linked to on the first page of this thread.
They'll work on the stock split rims, right? I'm now thinking I want to stick with original rims, otherwise it'll be awhile before I can afford to upgrade.
How about duals? Is there enough room or will 11R20s rub against eachother? I've read some conflicting stuff about this.
11R20's are recommended for 8 inch rims. The deuce rims are 7 inches so probably not as big of a risk as some other wild combos I have seen around here. Problem is .. good luck finding them XZLs. If you are going 11R20s then the military surplus tires are pretty much Firestone T-831s :
Gays Tire Service Website
New here they are $250, used you can get them for about 125-150 I think. So singles up front and 8 duals + tubes and flaps in the rear - 8 x (150 + 40 +10) = about $1600 + mounting .. and then you still need to single the front - add another $1000 for that.
Personally, I think a lot of guys single their trucks to save money on tires :-D:-D:-D
Here is a foto of what that looks like (singles up front duals in the rear).
Whatever combo you are contemplating, someone here has already done it and posted fotos. Do a search (T-831 for example) and you'll find more tire combo fotos that you ever dreamed of.
kochevnik
Colville WA
kochevnik
Colville WA
I'm planning on running single Firestone T831 11.R20 radials on mah deuce, but haven't figured out what wheels I want to mount them on. I'd like to run modified HEMTT wheels, but they're too wide. The Canadian bead-locked wheels are a viable option, but I would prefer wheels with even less backspacing. What about the older one-piece wheels from the Ford trucks & schoolbuses though? Are those all 22's, or are there any 20" one-piece wheels with the right lug pattern, width, and backspacing out there?
Short answer. No. Those older Ford rims and the Hino rims are all 22.5s as far as I know.
The other problem with those is that unless you can find the newer Hino/Fedex truck wheels, you are looking at ford rims that are 30 to 40 years old. Not optimal IMO.
blacktop
Minot ND
kochevnik
Colville WA
Not trying to rain on everyone's parade here :smile::smile::smile: - just trying to point out all the facts.
Couple other things to consider - the stock NDT tires do NOT last very long. You can do the search here, I would say they last 10,000 to 15,000 miles MAX. For comparison, big rig tires last hundreds of thousands of miles if well cared for and then can be recapped.
If you are worried about split rims (I know I'm not thrilled about them) consider that if they are mounted as duals on the tandems, the ring that is so dangerous is on the INSIDE of the duals.
http://www.steelsoldiers.com/deuce/18810-deuce-tire-rim-break-down.html#post191771
Moral of the story : Always get someone else to change and mount your tires and you don't have to worry about split rims on the rear tandems. :-D:-D And the T-831s are as ubiquitous and cheap as anything out there (and look as good as the XZLs).
Also remember that almost all of the modified singles (HEMTT) rims being hawked around here are two piece rims, which means if you have enough muscle power, you can change them yourself. A lot of guys don't even carry full spares on their truck, they just carry and extra tire (w/o the rim).
TANSTAAFL
kochevnik
Colville WA
****, that is a good looking truck!
That there is readyman's Lil Ruthie :
http://www.steelsoldiers.com/deuce-...il-ruthie-gets-some-new-shoes.html#post144402
LOL - I think I have hundreds of fotos of different tire combos I found on this site.
Edit : whoops - I screwed up - got confused because first time I saw that it was in the thread above but it is actually that sage man of infinite wisdom :) :) :) M1075s truck :
http://www.steelsoldiers.com/deuce-modification-hot-rodding/9462-new-tire-setup-deuce.html#post87566
TexAndy
Bee County, Texas
What rims are you using on that truck? Those fronts don't look like standard M35A2 split rims.
And is it just my imagination or are those front tires alot wider than the rears?
deathrowdave
84
falmouth, ky
I have installed 11R /22.5 1 piece rims !!! Steers way eaiser and tires are everywhere. Rims came from a recycle trash truck. about 4" total taller than 9:00 20s.
11Echo
94
CT W. R.
Looks great!
Did that start life as a dump truck from the factory or did you convert it from a regular M35A2?
Looks nice. Got any more pics?
My tipper is a M342A2 Deuce Dump truck. Just not a lot of them out there. It has reinforcement plates along the frame rails and a few other items different from a M35. Pics in other threads I've posted in.
My tires I bought used military surplus, 90-95% tread. I paid more than Blacktop did for his and what Alredneck has been selling his for.
I paid $33 for 11R20 radial tubes and the 9.00x20 flaps are ok to use in the 11's.
jesusgatos
on the road - in CA right now
Anybody gots any input for me here? Looking for 20" one-piece wheels?
ctmustang
Thomasville-N.C.
I just seen a guy I know pick up 7 3958520 from our military tire retailer for 600 bucksand they are basixally brand new. If I hadn't seen the reciept I wouldn't have believed it. I bought stock 900-20s for my deuce which were brandnew with flaps and tubes for 75.00 a piece last year. There are deals on tires just keep looking.
