Primer pump leaking any ideas??
Steamynachos
Calgary Alberta
Well I changed my fuel filter and tried to prime the fuel system as stated in the TM. well all i get is air in the line now it seems that my primer pump on the dash lets air into the line when I pump it :( does anyone know what size rubber grommets are on the pump I have some that looked right the but I cant get them to fit in the tube of the pump and it still leakes when I tried the next size down :?:
3,182
What kind of engine is it? Can you post a pic of the priming pump. If it's a cummins 220, 749 or 855, it's only 2 o-rings on the shaft. Sorry, don't know much about the 5 ton, just clicked here by mistake, but i do know cummins.
70deuce
126
Franktown, CO
Repaced Cummins 250 primer pump O-rings
Finally had to replace the two O-rings on the dash mounted primer pump. Not the greatest pictures of the assembly but you can see why I had diesel dripping off the plunger. Note the O-ring split. 36 year old O-rings tend to do this. Very easy to replace. 5 minute job and cheap repair. The size of the rings are 3/8" ID, 1/2" OD x 1/16"wall. Got mine at Lowes # 0562. M809 Unit Maitenance TM 9-2320-260-20 page 3-62 shows how to dismantle it. !972 M818 was the patient.
