Priming T/C Oil Pump
m38inmaine
62
Maine USA
I am trying to prime my transfer case oil pump, following the instructions in the TM. I can pull a steady flow of oil through with a suction gun but all I can get by manually actuating the pump is a dribble. Is this normal or should I be able to get a steady flow manually?
Gamagoat1
44
Kiowa, Colorado
It's only a dribble. The stock and diameter of the little piston can't pump much. The dribble drops down inside on the top of thr gear, this spreads as the gear turns.
Gamagoat1
44
Kiowa, Colorado
Id add the Lucas if you've never done it before and always if you drain. The main thing is to insure it supplies the oil to those gears, and it's
such a bear to get the dog house up just to check.
