CommoChief
- 43
- 28
- Sayre, PA
I am trying to connect an RT-524 to a VIC-1 system. The problem I am having is the jumper cable from the center jack on the RT mount
is a straight plug and the power connection (jack immediately to the right) takes a cable with an angle to the left. Therefore, the two plugs
will not work together as the power cable interferes with the jumper cable to the VIC-1. My question is...would it be easier to find a different
base/mount for the RT-524 with different jack set-ups or look for a straight power cable?
Thanks in advance....Bill
