Problem with air pack/brake booster
Tomcat44056
Independence oh
I’m working on a m35a2 that has been updated with the dual master cylinder an short air packs. It is losing brake fluid through the vent tube that goes from the air pack up into the engine compartment. I would assume that the air pack seals are bad, allowing brake fluid to pass into the air side?
fleetmech
405
Connecticut
If you've got brake fluid coming up/ out of the underhood vent, yes the airpack seals are gone. The pressure developed in the hydraulic portion of the airpack is much higher than the operating air pressure, so when the main shaft seal fails, fluid will work its way into the air side.
