Problem with an oil leak on a LDT-465 White Engine
skinnyR1
Burlington CT
My input on the transmission was bad as well, and would put out gear only at highway speed into the bell housing. When I stopped, it would dump out. You would have to shut it off for the oil to come out of the clutch, flywheel and bellhousing. If I drove down the highway long enough, the clutch would slip. Stop, shut it off and let the oil come out, and it would be ok again for a while.
There is a lot of conflicting info on the forum, as to whether or not this is normal or not. It is normal in the sense that it happens to alot of trucks. But I think that no matter the trans fluid level, if everything is as in good shape, it shouldn't leak. It leaks due to wear and tolerances opening up. If it leaks at the level it's intended to be, you have a problem. This problem can be alleviated by dropping the trans level, but that is probably only a patch fix and doesn't get to the root of the issue. Its your call.
My transmission had a ton of slop on the input shaft, which could be attributed to a bad front bearing and shaft. The transmission was replaced to fix this.
FloridaAKM
395
Gainesville, Florida
If you take worn muffler bearings & apply several buckets of steam; the muffler bearings tend to swell enough to stop the leaks & fix the clutch slippage. The secret is to hold the shaft with a left handed monkey wrench till the swelling is just enough to stop the leak. If you wait too long, the skyhook might crack & botch the entire job... ;)
andy3
12
Suwanee, Ga
Gimp, the blinker fluid was labeled winter blend. I am having trouble finding the spec for the summer blend. Is it in the -20 or -30 TM. It gets hot in Ga and I don't want to screw anything up.
rustystud
3,394
Woodinville, Washington
You guys are terrible ! Next you'll be sending someone after a muffler computer ! ;) Wait ! they do make one ! :)
