llong66
- 2
- 0
- kokomo, In
Hello all, I have run into an interesting problem. It started when my oil pressure light quit working, checked bulb and such and ended up pulling the dash. I had a bad trace in the circuit board I repared. I have everything back working now except when I turn on my brights, my inst lights and fuel gauge go out. I have checked grounds, have LEDs for my inst lights which all work. I cleaned connections, etc. If I take the
bright indicator bulb out, all is fine, I have tried switching sockets (that is a regular bulb) run the traces on the circuit board, look over schematics, all with no luck. Could this be the switch in the steering column? I am at a loss for any possible solution. Any other ideas?
Thanks much!
Greg
1985 M1008
Thanks much!
Greg
1985 M1008
