Well sh@#.... A five cent resistor solved the problem. I cut the yellow wire
that leads to the temperature sensor and put a 680 ohm resister in series. It
turns out that at some point they swapped glow plug controller
modules. I got a feeling that the temperature sensor isn't the one that should be
being used with the current glow plug module they installed. In any case, I went
to the BMV for the vehicle inspection. It took about five minutes for them to
come out and do the inspection and it started right up
. I then went to the title
department, parked, stood in line for another five minutes and she started right
up
. I still need to check all the glow plugs to make sure they are all in good
condition. I got a feeling that there might be a couple that aren't working.
