Problems with rear wheel seal.
reom34
Canary Islands- Spain
Hello from Spain.
Sorry for my bad English. I hope you can understand me.
I have a Reo M34 1950 with gas engine and one of its rear wheels have a problem with the inside seal.
It is the third time I change the inside seal and the inside bearing.
All its look like right but after one or two hundred km the seal leak again inside the drum and the brakes in this wheel fails.
Any idea about it?
NDT
5,883
Camp Wood/LC, TX
This can happen if the axle vent is plugged. Pressure builds up as the axle heats up, forcing the oil into the bearings and past the hub seal.
Valence
612
Davis County, UT
Hey, we can understand your English just fine! I hope you can understand ours...
Are you putting the cork into place in the keyway slot? Is the cork piece big enough to fill the space? The cork piece should require some compression for you to squish it into the keyway and UNDER the outer bearing. Just to be clear, starting from the inside of a rear axle, the order of assembly should be:
  1. Inner grease seal, press fitted into place on the spindle
  2. Inner bearing
  3. Hub and drum assembly
  4. Outer bearing
  5. Cork seal just under the outer bearing, in the keyway. I also add some RTV silicone, but honestly it's hard to have a clean surface for the RTV silicone to adhere to because you have a grease packed bearing above.
  6. Outer oil seal - I also add some more RTV around it's keyway tab. Make sure you orient it the correct way, it matters which face mates to the outer bearing!
  7. Inner spindle nut, and preload adjustment
  8. Tabbed lock washer
  9. Outer spindle nut, torqued to specification
  10. Bend at least one tab on the lock washer to ensure the outer nut doesn't turn. Best practice is to bend two tabs, one tab bent down on the outer nut, and another tab bent on the inner nut.
gringeltaube
Staff Member
2,269
Montevideo/Uruguay
That (inside) seal #7521649 can- and will leak (gear oil) after the outer seal #7061238 has failed to hold the oil inside the axle tube.
Have you checked the condition of that oil seal? Beware of the poor quality aftermarket seals, out there... See this thread...
G.
gimpyrobb
dumpsterlandingfromorbit!
27,785
747
Cincy Ohio
You need to take pictures of your work and post them here. You can take the pictures in Spanish, we will be fine :)
If memory serves me, Reom34 has posted pics in the past(I think of his motor) and does excellent work. His truck is a fine example of craftsmanship.
