progress on injector nozzles
Csm Davis
406
Hattiesburg, Mississippi
At what point do we need to start thinking about putting the oil squirters in our little engines that can? You guys are killing me, I am thinking about a p-pump with 480 injectors, squirters, second turbo, bigger exhaust header and pipes, mrap intercooler radiator assy, electric fans, and dual filter assemblies, what else would I need to keep from melting the engine down other than a light foot?
Sent from my SM-G900V using Tapatalk
74M35A2
341
Livonia, MI
Our engines are equipped with piston cooling nozzles already.
Need to advance ignition timing, it supposedly brings EGT way down, and makes sense if you think about it. The marine 480 injectors will make power but will likely be hot EGT and smokey as their spray angle is not optimal for non-marine pistons. NEVRENUFHP just came up with some improved injector nozzles with the correct spray angle.
grendel
12
Derry, NH
I should have my injectors out and in the mail to you by Thursday. Doing an air to air charge cooler (with intake manifold) and stacks. Timing is already 16 degrees. Anything else I should consider? I think the HX40 is plenty of turbo, but I could go bigger with a T6 flange manifold I found.
nevrenufhp
Sacramento
you should be clear sailing. Watch the pyro during hard pulls, but I doubt it'll get all that hot.
74M35A2
341
Livonia, MI
Besides switching to a P7100 pump, that's probably about it for the stock 8.3L. You could switch to a newer 24v 8.3 and convert it over to mechanical injection (been done on YouTube), but at that point if changing engines just go with something stout like an ISX, Series 60, etc....
nevrenufhp
Sacramento
These pumps don't have a fuel plate. The nuts on the back are the equivalent of sliding a plate forward. The gov springs are covered in that long thread "who has bumped up the power". You can tighten the stock ones, add washer shims, or get a Dodge gov spring set. The 3k kit will let it rev to around 2800.
grendel
12
Derry, NH
Thanks, doing this myself, so just confirming. My brother's stuck in Atlanta (the Cummins tech), so no help. I believe you also said to back nuts completely off with your nozzles?
nevrenufhp
Sacramento
I wouldn't start at the max, unless you're empty all the time. I highly suggest you ease in to all that fuel. Start with it close to stock setting on the nuts, and work from there.
grendel
12
Derry, NH
This is my truck :) :
By definition, it will be empty all the time... granted, it got a Pete air ride rear suspension... but it's no where near what it was when hauling trailers on the king pin :gimp:
Jbulach
2,414
Sunman Indiana
Received my hi flow replacement 8.3L injectors from NEVRENUFHP with new nozzles in them. Here is a preview:
How these working out for you? Grendel? Nevrenufhp? Bueller? Anyone?
I want to add a little more power, but l’m already pushing EGT to the limits for my comfort level, completely stock. Rereading some if my favorites and looks like in post #1 Nevrenufhp claims lower EGT with the same or slightly more power with these nozzles?
nevrenufhp
Sacramento
I quit doing injectors over a year ago. The bad thing with the nozzles in a 5 ton, is the size. They are too big, and dont atomize well at all. What I did find, is using some injectors from a newer 300hp 6CT, then playing around with the fuel rate will give a mild increase. Yet it'll burn much cleaner with cooler EGT.
Elijah95
Certified Rookie
1,247
1,222
Georgia
What’s the part number?
74M35A2
341
Livonia, MI
Cute, so what about the ones I bought from you a while back?
