Snow is pretty much all melted, rain clouds passing overhead. Today I made a dash outside to at least accomplish one roof joint. As most of us M109A3/M185A3 owners know, the white caulking AM General used for sealing panel joints probably wasn't made to last it's 22+ years. Almost every joint, where the caulking was used, is all cracked and shows some water infiltration. Here in the PNW, it's also a nice home for moss to grow out of. Though there is only 1 major leak evident in the van, I am going to redo all the roof panel joints within the next couple weeks...weather permitting of course. I've got a tarp covering the roof at the moment to keep the areas semi dry. I tacked the easiest seam to get to, the rearmost one. I just used a flathead screwdriver with a 3/8" end and scrapped out the caulk, used a wire brush to clean the area, then scrubbed the area down with rubbing alcohol. In the process of stripping the paint back I noticed I had a total of 4 coats of paint that's been applied to the truck(1st coat
riginal forest green from AM General, 2nd coat: Tan CARC, 3rd/4th coat: 3 color camo CARC). I used some polyurethane based roof/flashing sealant for the joints (discussed in a previous post). I decided to seal the rivets as well using Geocel Pro Flex Multi-purpose Brushable Primer. Both sealants I used are paintable and permanently flexible (we'll see). There really is no reason why I used the two sealants. I suppose I could have just used the Pro Flex for everthing but it's pretty runny stuff and I'm not sure I would have gotten the nice fill type of application on the seams. I do plan on CARCing her this summer if I can afford it and be able to still buy it. I'm not too happy with the Gillespie paint I used on the hardtop....TOO GLOSSY!!
On the inside of the van, I used some phosphoric acid to kill the rust. I won't really tackle the inside until all the roof joints are sealed up. I plan on pulling all the side panels to see what's in there. I'm going to put some drains at the bottom of each wall. The plan is to extend a 4-6" clear tube down with a petcock on the end. A clear tube will let me know if I have another water issue and the petcock will keep critters from crawling up into the walls. I originally planned on just drilling a couple 1/2 inch holes on the bottom of the walls. However, when I got into the van I noticed I had a hibernating yellow jacket there all cuddled up in the corner of the door. Then I thought shoot those walls would be a great place for a yellow jacket nest. Anyways, I'm rambling on too much now.
The floor actually looks worse than what it is. The entire floor and the inside of the walls are coated with a thin layer of tacky tar. The rust color you see on the floor is a result of the leak I had in the wall that rusted out the floor panel carriage bolts. The rust "powder" got on the tar and is nearly impossible to remove. I treated the bolt holes with the phosphoric acid sol'n. I have decided this is where my two 9.00x20 spare tires will reside. I'm going to construct somekind of a mount that'll keep the tires upright and secure.
Hmm, probably should maybe run some wiring in the walls for future use (great something else to add to the already long list of projects
Projects completed:
Caulked rearmost roof panel joint
