Someone talked about paint drying time - this is the Rapco paint and even today the drying time changes the color to what it suppose to be. Couple more weeks it should harden a little more and turn the better color.
The bracket next to the master cyl on Dingers - made the replacement in about 20 minutes using Debs as a template.
Got Debs front flex brake lines on - she helped pull her front end getting physically ready for the engine call to be made to me that is is ready for pickup. Got the other flex on the front end to change out and the rear one.
Have to replace the diff seals and her transfer case seals are not leaking like Dingers are - When he was filling the transfer case he tipped over the gallon of lube in the fuel well - I was underneath and got a BATH in gear lube. The big puddle is from the output to the front drive leaking - so replacing both of the seals which are on order.
Sure hope Debs front end is NOT in the way for the M43 or it gets crushed
All I can think about is roasting a pig and seeing my friends
![A toast to MV's :beer: :beer:](https://www.steelsoldiers.com/images/smilies/beerchug.gif)
