Project Time Once Again
2,494
Zout does impressive work...it is only affected by the infamous CR bottle...or the clear stuff with cherries in it...that turn white quickly...
Anyway...:grd::not worthy::beer:
Zout is a Brother from a different Mother...but CAMO is proud to have him as a friend and a detached member!!:driver:
zout
155
Columbus Georgia
I am proud to be a member of CAMO no matter how low on the totem pole I am :jumpin::jumpin::jumpin::jumpin:
Infamous Crown struck again :roll:
I am a better helper so I helped Dinger on his frame today - he torqued all the components I laid in place and just sitting there - then he went onto cleaning everything up - even the housngs - if it ain't clean ya can;t fix it or see whats wrong - and if there is chit on the grease zerts CLEAN EM [thumbzup]
So I had to play Lucifer and roll one of his tires down once we flipped the framework - MAN those tires are awesome - did I mention they are Kevlar sidewalls.
Long way from being done - but a long way from where we started on his - he is excited once again.
Even if I am a displaced CAMO member - they are here in heart [thumbzup]
Deb's tub rolled over and played dead - had to get to the underside supports to cut them off and going to replace both of them - plus support the above welded in floorboards with underside support. When all done with this it will get bed liner coated.
PB - my Crown box is Empty :sad:
zout
155
Columbus Georgia
No fair PB - you have a 3 point hitch and I would have to get an ole rusty navy anchor and throw out behine the jeep to dig a ditch roflthat is if Deb ever lets me drive it.
Did I mention you have a pigmy Hardtop rofl
2,494
Just a friendly observation Zout.
Maybe you might kinda sorta mention to Digger that he needs a wheel to put his tire on, and a tub to mount his fender on??:roll::roll:
I know we all get excited and wanna push the envelope sometimes...but there is a limit as to what will and will not work:shock:
zout
155
Columbus Georgia
DC - I have a really nice tractor waiting for you as well :jumpin: .
You are more than welcome for dinner when you get back home - steaks will be on the menu.
Just got done shopping at KW once again - ordered the supports for the drivers and passengers side - spent more time today after destroying my 4 inch grinder removing them - some dummy never installed the safety handle to the side of the grinder and sticks his hand over the venting hole - 7 yr old grinder anyhow (how is that for a lousy excuse) :roll:
Going to repair the bottom section - no its not original and totally perfect - but this baby is going to get used. Spent some time pounding dents as well.
zout
155
Columbus Georgia
Stuipd Question for anyone reading this - on the passenger side below the cowl - there is an endented housing - circular. I have all the TM's printed and have looked hard - WTH is this area for ?? There is a 3x2 inch metal plate riveted to the inside nose of it as well - nothing is engraved on it - this must be for a decal of some sort ??
zout
155
Columbus Georgia
AHH - appreciate it. I almost thought that and it has to be in the novel collection of printed TM's - must have flipped past it.
I bet behind that metal plate then is the access hole to install the plug = THANKS - now I have to look for yet another piece to the jeep.
tigger
Medic.
50
Butler TN.
I have been fallowing your progress on this and you are doing a great job! i hope to have my jeep at the GA rally this year
zout
155
Columbus Georgia
got the remainder of the pass support cut out - leveled and cut a new template - got this spot welded in and tacked on the edge side in between spots - I will get the other triangular piece to this tomorrow night as I am a big fat lazy sissy and time to eat dinner.
Besides that - maybe the supports will be here tomorrow night and I won;t have to start on the drivers side yet :jumpin:
1,156
Since you and Dinger both have 24V vehicles, it would definitely be worth it to install a slave port and buy a slave cable.
