codematic
- 1
- 3
- long beach, ca
im finally getting to my floor pans in the CUCV Blazer. I am seeing many differences in the pans ordered (mill supply), but i see the exact same replacement pan designs with LMC and everyone elses.
anyone have this same issue?
Where can the proper replacement pans be found?
Issues
The replacement floor pans for behind the front seat have a tight 90 bend up to the rear cargo area. This bend is not the same as the slight curve the factory floors have. Im only replacing the driver side, not the passenger side so they need to match.
this is a pic of the passenger side to show the details.
1) notice the curve from the horizontal to vertical surfaces
2) the addition of the bump out for the frame rail to pass under
![20180819_112331.jpg 20180819_112331.jpg](https://www.steelsoldiers.com/data/attachments/506/506399-9edb717ac2d9ec6fe3e693e571d89ffd.jpg)
Floor pan ordered from Milisupply, but also the same as the one on LMC truck and other places. note the sharp bend and the lack of the frame rail bump.
![20180819_112348.jpg 20180819_112348.jpg](https://www.steelsoldiers.com/data/attachments/506/506400-0402621ace31addb8baad254663ba0ad.jpg)
3) the panel level drop at the door seal is not in the proper place, its 1.5 inches too far to the rear and not deep enough.
panel pulled away from the sidewall to show the detail..
![20180819_112448.jpg 20180819_112448.jpg](https://www.steelsoldiers.com/data/attachments/506/506401-af2de5d73f248843071aa0c780f5d739.jpg)
so where can the pans be sourced that actually fit?
i don't have a choice i need to replace nearly the whole pan as there is either large holes or pin holes all over it.
thanks...
Issues
thanks...
