Proper Type & Quality of Under Hood Hose Clamps
tjonesdfw
70
Coppell, Texas
I've heard several guys talk about the proper hose clamps and constant tension clamps for under hood hoses. Several on my truck are clearly some auto parts junk and I'd like to replace with the correct style clamps when I install all new hoses. Appreciate any advice you guys may have.
Glider
233
South Pittsburg, TN
These are supposed to create twice the clamp force of parts store type. I bought two orders of these but haven't tried one yet.
frank8003
4,988
Ft. Lauderdale, Florida
Here is description of the two upper radiator hose clamps.
Product Details | HOSE CLAMP
4730-00-204-3491 A clamp in which the body (band or wire) completely encircles an item and distributes a relatively even amount of pressure throughout the entire 360 degrees (6.282 radians) of the periphery of the item to be compressed. Its compression quality is dependent upon an integral screw mechanism, (screw, bolt spring compression and the like mechanical fasteners), or it may be applied by a device not integral with the clamp itself. It is specifically designed to prevent leakage between a hose and its attaching connection(s) when the body of the clamp is round or circular. For square, rectangular, or irregularly shaped items, see CLAMP, HOSE, SPECIAL-SHAPED. Excludes CLAMP, ELECTRICAL; CLAMP, LOOP; CLAMP, FIRE HOSE, SHUTOFF; FERRULE (as modified); and HAND SCREW.
As You may read here these are made by many and they all must comply with original design. Even Navistar makes them so You have to shop online
frank8003
4,988
Mogman
10,336
Papalote, TX
The HMMWV is no different than any automotive application, any quality worm gear clamp will do the job no problem, unless for some reason you go to silicone hoses then you should use T-Bolt clamps.
