Pros and Cons of zipper boots
bsorcs
13
New Orleans
I put a couple of these nasty-green silicone puppies on in November of 2010. About 4k of highway and around-town miles since and no cracks/leaks/etc. Probably should not have said that!
With everything clean, single-person install was not difficult. I'll follow the same route in the future. Clamps are a neat idea.
Motorcar
San Antonio, TX
RedBeard... you may not be able to just "unzip" them and put them back together, chances are that the pull part that zips together has been cut off after installation rather than just letting it hang. They were designed to ease installation/replacement and not go on and off multiple times. Also, it may be near impossible to get all the grease out of the zipper to allow good sealant to adhere. Got mine from Erik's and have had no problems so far.
197thhhc
15
Williamsburg, OHIO
I have access to about 4 different kinds of zippered boots from my suppliers. I am inthe process of checking their quality and where they are made then I will start carrying a full line of zippered and non zippered. Should be within the next 2 weeks.
Redbeard I would leave the old ones on until they rip. I have never had luck reusing them .
Varyag
Garfield, Washington
I have been running the Kia ones from korea for about a year and they seem to be holding up. I take a close look at them as part of normal PM and they are holding up fine. I got them from Erik's.
m16ty
228
Dickson,TN
In my experience,the only remotely good zipper boots are the genuine military boots. They still aren't as good as the silicone non-zipper boots.
197thhhc
15
Williamsburg, OHIO
Has anyone tried the black zipper boots with rivets. If so how are they holding up. They look a little better than the zipper boots I have on my truck now.
shenkmen
12
Lancaster, PA
I've tried them. Same garbage as the others. Cracked in 9 months. I've tried the gold zippered and the silver zippered with and without rivets. All junk.
Wolfgang the Gray
36
New River, AZ
Pro there easy to install
Con they not water tight
I installed solid boots first go around, second time I used zippered.
When you say they aren't water tight, does that mean you shouldn't take it fording or you shouldn't let the garden hose splash water on them when washing the truck? Just want to be sure I understand your meaning to the correct level.
MikeON
12
Lucinda PA
I installed non-zipper "silicone" boots in Dec. 2012. They lasted less than 3 years and 330 miles of very easy driving. I'm thinking of having them analyzed to see if they were really silicone. I now have non-zipper rubber boots installed.
dilligaf13
33
south, florida
Are there multiple manufacturers of those lime green silicone boots or are they all the same?
Wolfgang the Gray
36
New River, AZ
I read through the thread and may have missed it, but this question gnaws at my mind like a rat on cheese.
What is the purpose of having boots with zippers? From what I've read here, people put them on & leave them until they wear out & need replacing. A zipper (to me) would seem to indicate they are made to be opened and closed frequently (like the fly on jeans). I looked at the boots on eBay, both with and without zippers, but can't see what advantage they would offer.
Someone throw me a bone, please.:shrugs::confused::???:
rustystud
3,389
Woodinville, Washington
The original factory ones where made of a rubberized leather and didn't last all that long. So they had zippers to help in installing them without removing the whole wheel assembly. Later the military went with rubber ones but kept the zipper. There are after market ones available since the NOS ones are usually junk now (remember being made of rubber and now old) but the after market rubber ones are cheaply made. The silicone ones came out recently and at first they seemed to be a great fix, but I think to many companies are making them out of cheap materials and they are not holding up like they should.
Wolfgang the Gray
36
New River, AZ
Ahhhhhhh, now the light comes on. I kept reading about people pulling the wheels apart to relube everything so I didn't think installation was the purpose of the zippers. Thanks for the info. Someone needs to get the molds for the boots & start making quality units here in the US.
rustystud
3,389
That would be great but remember you have a limited market. Also if you make them too good then after you sell off the first batch no one will be buying anymore as they will not be replacing them !
aleigh
53
Phoenix, AZ & Seattle, WA
I've never seen any of these in person but from the pictures I've seen on the Internet and given that they were originally coated leather I wonder if they could be made from heavy Cordura or one of the other ballistics. The abrasion resistance of that material is good, and it's waterproof / greaseproof. Could be doubled or tripled or backed with tarp if it needs foundation. Temperature resistance would be poor with Cordura though. I sew heavy things for other projects and these don't look that complicated but I am mostly just wondering out loud.
Wolfgang the Gray
36
New River, AZ
You could always prototype?
