PTO cover plate interchange?
CUCVFAN
Gunner's Mate First Class
53
Jarrettsville, MD
Does anyone know if the PTO cover plate from an M809 transmission is the same size and bolt pattern as the one on the Allison MT654 in the M939 trucks? Without looking, I think they are both 6-bolt, and I assume they would be some SAE standard size. But, you know what happens when you ASSume...
Thanks!
1,172
They each have different NSN #s.
CUCVFAN
53
Jarrettsville, MD
Yes, I know. But, as with all other things military, that does not really mean that they won't interchange. They might have different thickness, rolled edges, etc...
The M809 cover NSN details call out all of the vital measurements/dimensions, while the M939 does not. At least, not that I could find.
It's pretty hard to get to the cover on the M939 to get accurate measurements, so I figured I would ask if anybody knows for sure if they will interchange.
1,172
Sorry, I only posted what fact I was sure of.
As for standard SAE size, yes, they should be the same (as far I I know).
CUCVFAN
53
Jarrettsville, MD
Thanks, DH. I prefer facts much more than conjecture, so I do appreciate the effort.
I might just try to measure mine and then swag-compare it to the specs of the M809 cover.
I, too, suspect they have the same pattern/size.
1,172
Maybe the depth of the cover(outward) could vary.
m16ty
211
Dickson,TN
I'm 99.9% sure they are the same. The only reason it's not 100% is that I've never actually tried to swap them out but I've probably seen at least 100 6-bolt PTO covers and I've never seen one that wouldn't interchange.
I've got a deuce trans sitting in the shop that has a cover that says "Mack" in big letters on it. I pulled the PTO and used a old Mack cover I had lying around the shop just to plug the hole.
