Pto hydraulic pump
AlexS
Wisconsin
My hydraulic pump bit the dust today on my fmtv dump truck. Does anyone know a PN or alternative for the hydraulic pump. The number I got off it is C35.5l 33364 sauer sundstrand. Also if anyone knows where to source a filter for the wet kit that would be appreciated. PN 931558. It’s a A0 m1094. I’ve looked all round the forum but no luck. Would a hydraulic pump from a winch equipped truck be the same? Thanks everyone once again.
Ronmar
8,407
Port angeles wa
You might also be able to approach this from another direction. Look up the PTO drive gearbox P/N, and the manufacturer should have specs for type pumps or output interface it is compatible with…
Skyhawk13205
323
Alaska
It look like the PTO PN is 276XMFJX-D5XK per -24 LMTV TM, I could not find a parts desc for the 276 all I could find was for the 277. Most of the numbers line up. It gives an output type of a 2 or 4 bolt sae b whatever than means, I don’t know if the spline is the same pitch or diameter. See attached for PN desc
AlexS
Wisconsin
So I found a pump that’ll work and is close to the stock one. I went through hydraulic supply company.
613871202
SALAMI 2.5PB32D-R55S3 PUMP
and you also need to add the rear port headplate
313803502
SALAMI 2.5PB/ REAR PORTS COVER SAE 16-12
You’ll also need plugs for the top and bottom as well as different fittings for the cover but they’re cheap if you go through surplus center
