PTO removal in scrap yard
MAZ537
23
EU
Dear SS members,A friend of mine told me about an m35 he was found in a scrap yard.It is an old one M35 with the continental gasser engine , winch and bumper are gone but pto and shaft are still there Can you please share some info about what size wrench fits the PTO bolts please ?Also can I remove it complete with the shifter (if it is still there) ?Anything else I might take as well ?Thank you,G.
NDT
7,363
Camp Wood/LC, TX
PTO nuts are 9/16". You need combination wrenches for this. A catch pan for the oil. Vise grips for the studs.
1,824
The shifter is bolted the master cylinder. Save the short little bolts. Also, gasser shaft is different. It can be used but some clearancing will be required.
dilligaf13
33
south, florida
10-15 pounds. Once the bolts are removed it'll usually stick on there, because of the gasket. Once you break it loose it won't come crashing down like a ton of bricks but does requires at least a firm grip, with at least one hand, to prevent it from smacking you in the noggin.
Scar59
42
Mt. Eden, KY
Thanks all for the help!
Any idea how heavy is the PTO ?
About 20 lbs. Not to bad unless you drop it on your foot. Take a good set of standard wrenches and other assorted mech's tools.
Mind the gasket thickness, it will help when installing it.
rustystud
3,376
Woodinville, Washington
Agreed. $800-1000 for the PTO plus winch and shaft is a good deal. Just my 2cents
This is assuming you actually find one. They are getting extremely rare. That is why the surplus places are getting $600.00 and more for a good used one. If it's the double one ( front and rear shafts) they are going for almost $1200.00 . So if you find one for under $300.00 your doing very well. Remember they only fit this "one" application. The Spicer 3052, 3053 transmission.
