PTO's
pa.rich
Mike, would a heavy duty cable be a possibility for actuating your pto? Alot of dumps have that with a 2" knob on floor for it.Is that needed for the dump or the winch? Might simplify things in that tight area.Either case it could work. and allows some flexibility in that area.
mangus580
283
Western NY
I am looking for the original dump linkage... My custom job works... just want it 'right' if I can. BTW, I use one of them cables to control the valve :)
gringeltaube
Staff Member
2,688
Montevideo/Uruguay
mangus580 said:
Wow! that looks like the correct linkage!! :)
If anyone knows where to find one..... I sure would like it.
The only "correct" (OEM) parts of the linkage shown in the pics are the lever, shaft and crank behind the drivers seat. The rest was custom built because 1st) I didn't have the original linkage and 2nd) I didn't like that arrangement shown in the manual! (image below).
I wanted the lever to engage the PTO only after reaching a near vertical position, not earlier on its upward travel. Combined with a redesigned locking tab the possibility of accidental shifting was greatly reduced...!
And... it proved to work well, too!
Gerhard
peter.mcdonough
england , derbyshire
hi chaps , i am looking for a rear output pto for our 5 tonner , to be shipped over to england when i get more details (serial numbers ) i will be back in contact , so expect mail soon thanks boys . P.S. we are bore hole engineers and we use them to mount our rise on we seem to have a problem of tearing them to pieces , two so far dead so we need more . back to you soon nite .
jatonka
111
Ephratah, New York
I use the accessory drive on my M35s to drive the hydraulic system for the dump bodies. The transfer case PTO will do the job but you have to use a gear and chain system to clear the frame crossmember just behind the PTO. It works though and the transfer PTO is lubricated and a constant duty out put.
