Haoleb
- 11
- 18
- Raymond, Maine
Been looking for a good diesel generator for a while. Thought about maybe getting a nice little Honda gas portable...Then I saw some MEP's. Read more about them.. Decided that was what I wanted... And then a light came on and I remembered that about 6 months ago I looked at and drove an M923 not far from my house where a trucking company has some surplus equipment. And I remembered they had a generator I briefly looked at...
So I took a drive over there and sure enough the generator was still sitting there hooked to the back of a truck. Talked to the guy for a bit. It has not run so I do not know if it works but it is mostly complete. He wanted 4k for the whole shebang but at first I did not want the trailer. Finally settled on $2750 for the gen set and the trailer. Picked it up today and got it home. I went prepared for the worst.. flat tires (runflats? hard to tell without a gauge) or locked brakes etc.. One tire was at 50 psi the other at 5 lbs. Tires turned freely. Heck even the lights worked on the trailer which I just plugged right into my CUCV. Pumped the flat tire up and lowered the pressure in the other tire. Towed it home 9 miles no problem. Did not even know it was back there until I hit a hill then the old truck went up a little slower than usual.
Got it home no problems and started looking it over. One trailer hand brake is bent.. easy fix. and missing a lifting sling that is straight broken off. Looks like someone crashed this trailer into something because part of the nameplate is ripped off. No biggie still looks good elsewhere. Missing the little hand crank handle for the jack on the tongue.
Generator is mostly complete. So far I have spotted that the fuel filter/bowl is missing. I bought a new filter but now I need the bowl part as well and it looks like someone tried to bypass it becuase the hoses are not hooked up to the base anymore and appear to be connected together. Looking at the engine exploded diagrams it looks like someone cut the banjo fitting right off the rail and hose clamped directly to the hard line... Fantastic. It needs batteries. One of the neg batt cables is missing. Radiator has a spot in it I am hoping does not leak where some of the fins are corroded away in the middle. Some of the small cooling system hoses are all un-done not sure where some of them go. Still has some diesel in the tank and some oil in the engine I am wondering if someone tried to get it going and failed. No coolant in the cooling system. Missing the wrench for the output terminals
Hour meter shows 1009 hours I would assume after the reset. Looks like the main electrical box is complete no components missing or obviously fried looking. Looks like the gov planet sticker shows CC: F which I assume is condition code F- Repairable. Sure hope so!!
Next step will be to pull it into my garage and get to work taking all of the panels off so I can get in there and start putting it back together. I will also need to get a couple of batteries for it. Not a fan of optima's maybe I will just get a couple cheapie lead acids or I might try to price out some diehard platinum AGM's
I'll try to document as I go all of the stuff I find and fix to get it going...and then with some luck get it hooked up and running!
