Josh
- 12
- 38
- Portland, Oregon
Well my deuce sucumbed to the cold weather this morning. After nearly killing my two 1200CCA truck battieries I realized it wasnt going to start. I call my friend over who has a F250 to give me a little pull to try and get it started. Well after a couple quick tugs she wouldnt fire so I told him keep it at about 10mphs or so and put the truck in 4th Low range. It took almost 4 blocks for the truck to start to stay running under its own power. After 15 minutes or so of idleing to warm it up a little I set off. This was the first time I've had to pull start the deuce. I learned my lession about not having a block a heater. Unfortunatly Napa and all the other parts stores around me were out of magnetic block heaters, so I went to home depot and bought 2 cheap drop lights and some 100w bulbs. I put a drop light on each side of the motor. Hopefully they should put out enough combined heat to keep the oil from getting to think.
All in all it wasnt bad. She smoked like an steam engine as we drug her around. Soon she ran under her own power though, the smoke went away.
