Pulled the trigger on a M820
dburt
NE Oregon & SW Idaho
Yeah, SirBliss, but they are always a loooooong ways away from me! I wish the price of diesel would get down to where it ought to be- less then regular gas, and then I could afford to have one shipped or go get it myself.
802dot1q
SoIL
Sweet truck! Be interesting to know what kind of fuel mileage you get when you get her roadworthy. I don't know if the wind resistance from the box or the overall weight would be the worst culprit. I have lusted after one out here in SW Idaho at Idaho Motor Pool, you can see it on the website. Alex wants $17,500 for it, it has a new motor and trans in it, but a little rich for my blood. And I am afraid I could not afford to put the diesel in it to move it more then just around the yard. I'd like to build the ultimate off-road HD RV out of one. Guess I better start playing the lottery!
Well I filled it up on the first road trip. $200 and about 56 gallons. Ouch!
rrrr
Missouri
I put 25 gallons in my M932 in the right tank. $90, shows a half tank and I still had an empty left tank !
I figure it will cost me around $360 to fill it up....... OUCH !!
802dot1q
SoIL
Got a few more things done tonight. Picked up new hoses and clamps from NAPA. Put some metric o rings on the primer pump to keep it from puking diesel into the cab. Finished up the headlight project. Now sporting 100watt H4 bulbs in Hella E Code housings. Just need some wiper blades and I'll be in business!
Sunday morning we went to breakfast and did the shopping in it. It drew a lot of looks sitting in the various parking lots.
802dot1q
SoIL
Got a few more things done.
  • Replaced broken speedometer cable
  • New wiper blades
  • Replaced passenger side engine side pannel under the hood
  • Replaced under fender sheetmetal covers
  • Installed LED dome light
  • Adjusted headlights (wow these things are bright
  • Bolted down floor pans
  • Fixed driver's seat
  • Got a pin so the stairs won't fall off the back door
Drove it to work today too. I am just amazed at how easy this beast is to drive. Rides decent, steers like a 60's era Caddy and I think it has better brakes than my Porsche! Ever since getting the overhead set it will start with the slightest bump of the starter. A few more maintenance items and it will be time to start work on the box.
Here is a picture of it at Lowe's. I saw at least 3 people taking pictures of it. My electric umbilical cord is about to come loose!
802dot1q
SoIL
I think this thread has kind of turned into my build thread. Here are a few more things completed.
  • Diffs, transfer, and trans lube all changed out
  • Refinished and painted 8 FMTV wheels
  • Mounted 8 395 Goodyears on the FMTV rims (2 spares)
  • Bleached and cleaned the inside of the box.
  • Expanded it for the first time and cleaned and lubed all moving parts
  • Fixed grounding issue on instrument cluster
  • New glad hand gaskets and made a 50' air hose
  • A good cleaning inside the cab
  • Sold all 11 NDTs and wheels
  • Ram iPod mount on dash
  • 24v DC to 12v DC 20 amp step down converter installed in cab
  • 3 12v outlets (cig lighter plugs) in dash with toggle switch for all 12v power
  • Cup holders!
  • 500 watt pure sine inverter (24v DC to 120v AC) mounted under the bench seat
  • Pad locks everywhere
  • Adjusted the parking brake so it works
  • Top speed checked by GPS at 61.5 MPH
  • Completed 500+ mile road trip to Anderson, IN with no problems
  • Acquired a second (missing) ladder. Thanks John!
Now the upcoming list...
  • Recover both seats and install a springer for the passenger
  • Mount ammo cans for center console
  • Mount and plumb second fuel tank
  • Mount 6m radio antenna on front bumper (bridge feeler for the box)
  • Mount 2nd spare tire in truck
  • Fix axle gasket leak
  • Replace window in box
rwbrown72
33
Mt. Vernon, IL
  • Cup holders!
If you were a "Beaver" you'd build one big A$$ pond!
RB:doghead:
