gunboy1656
- 24
- 38
- Beaver Falls, PA
As I said before WD40, C clamp, a couple small blocks of wood (to protect the wood) and a rubber mallet.
About 5 minutes and it is out.
This will only work if they aren't broken off already (which I think his are).As I said before WD40, C clamp, a couple small blocks of wood (to protect the wood) and a rubber mallet.
Its also possible that also might saturate the wood and make it bloat and do more bad than good, paddle bit seems like the best idea!!As I said before WD40, C clamp, a couple small blocks of wood (to protect the wood) and a rubber mallet.
Why even risk harming the bed when you can get them out in 10 minutes with a drill??What is the opinion of heating the metal around the wooden problem until the wood starts to char which may shrink it a little? The charring might also lubricate the pocket on its way out like graphite does for certain applications. Though I do realize that this trick may/will make a mess of your paint if you apply too much heat.
AW HECK.......soak the wood with gas and lighter' up!
If none of this works I think a video camera and some C4 would create some smiles accross the board!![]()
Us old farm boys been getting them out for years by drilling in and then taking them out in pieces.![]()
Ten minutes per hole times three holes equals 30 minutes. What were you doing with that extra five minutes? Sounds like you wasted time you could have used to do some more PMS.I had to do this with 3 stakes. With a 3/8 inch 12" long bit it took probably 35 minutes total. It's very simple and only takes about 10 minutes a hole.
Chester got out, I had to chase him down.Ten minutes per hole times three holes equals 30 minutes. What were you doing with that extra five minutes? Sounds like you wasted time you could have used to do some more PMS.
I'm not convinced. Maybe I'll have to make a thread and vent.Chester got out, I had to chase him down.![]()
