I'm not a tax professional, but I did stay at a Holiday Inn Express...once.I was about to put up a reasonable argument. However, claiming it on my taxes is a good idea.
Why not add two feet all around on the sides of your deuce and m105. That would be one of the safest ways to up its cube.If you don't have the 2nd 105 trailer save your money and don't buy it.
Get some plywood and 2 x 4s and build sides on the trailer you have. You can go to 13'6" before hitting bridges on the interstate.![]()
Previously, I posted a pic of the manual that states that the M332 trailers were not designed to be towed in tandem over 10 MPH!.I forget where I saw it but I read that when pulling multiple ammo trailers it was recommended to keep speeds down to around 20. Wish I was at home on my comp to look through the manual.
Think even if you try it at higher speeds your going to need to reinforce where you mount the hitch pretty good.
